Would it be possible to add the "Sleep" option to the main Library Popup Menu, the one which appears when holding down the Menu button when selecting a movie (it contains, Queue Item, Add to Favourites, Movie Information.....) If this is possible and others support this could it go at the very bottom of the list.
I know I can map the "hold menu" button to sleep the system (which I have done in the Main Menu) but then I will loose the popup which I do not want to do.
Is this something that is hard coded or can this menu be editied manually as I would also like to remove a few Items I never use (Go To Root, Mark as Watched....)
I’m not sure if this is the correct place for a sleep button. There is currently on in the shutdown menu. Next version will have Menu at home screen bring up sleep menu.
Normally to sleep the system you have to back all the way up to the Main Menu, what I have done at the moment is map the Menu(hold) button to sleep the system whilst in Library mode etc... and re-mapped the Play(hold) button to bring up the popup menu mentioned in previous post. I have already mapped the menu at home screen to the power menu.
This works but it is not great as I would like to revert the menu button to delivered that is why I would like to see the sleep option added there, saves having to menu back to the root. I was hoping that this menu could be easily customised as apart from adding the sleep option I would have liked to remove other options that I do not use.
Question; can this popup menu be user customised as I looked through the .xml's but could not find any reference to it?
