I’ve just tried using ‘Adjust Display Refresh Rate to Match Video’ on the latest version of Rasplex. When the movie starts there’s a bit of flickering on the projector while it resyncs then projector shows its running at 24hz.
The trouble is, it then keeps resyncing so the screen will black out and flicker while it resyncs. This happens over and over again.
I’ve tried setting ‘Adjust Display Refresh Rate to Match Video’ to always and also start/stop.
Does anyone know how to fix this please?
I’ve just created a fresh install using 1.0 and still have the above issue. The projector will change from 60hz and match the movies 24hz but after a few mins the screen will black and the refresh rate seems to sync again. This will repeat again after a short while. If I switch off the match refresh rate it plays fine at 60hz so I assume enabling the matching repeats sending the sync settings every few mins?
Any thoughts please on how to resolve?
@tajhunt said:
I’ve just created a fresh install using 1.0 and still have the above issue. The projector will change from 60hz and match the movies 24hz but after a few mins the screen will black and the refresh rate seems to sync again. This will repeat again after a short while. If I switch off the match refresh rate it plays fine at 60hz so I assume enabling the matching repeats sending the sync settings every few mins?Any thoughts please on how to resolve?
Have you raised an issue on GitHub? See sticky at top of forum on how to do this.
Regards
