Adjust quality settings in main menu
Is there a way to adjust quality settings in the menu for all files, instead of hitting A during playback? My issue is that I can’t get the files to play in order to have the option of hitting A.
Ooh. That’s an interesting one. I’ll raise an issue to look into it. You can’t change the quality upfront, no, but sounds like that logic is broken when the server can’t transcode.
Could you please post details of the file you’re trying to playback? I think you mentioned elsewhere it should be DP’ing?
Thanks for responding!
Here’s a more detailed description of what’s happening…
I’ve got an XboxOne with the Plex app installed. The library is connecting just fine. When I play SD movies (the bulk of my library), it has no issues. But whenever I try and play my HD files – Inception for example (file info below) – it gives me the error message immediately, stating my Seagate Personal Cloud isn’t powerful enough. Which, I figured it wouldn’t be powerful enough if it had to transcode, but thought it would be fine at the specs below. I have no issues with the exact same file playing back on Roku, Browser, or Mobile, so the problem seems limited to the XBoxOne.
Anyway, any help would be awesome!
Thanks!
Media:
Video Resolution 720p
Duration 2:28:08
Bitrate 4295 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Container MP4
Video Frame Rate 24p
Web Optimized No
Has 64bit Offsets 1
Part:
Duration 2:28:08
File Inception.mp4
Size 4.44 GB
Container MP4
Has 64bit Offsets 1
Web Optimized No
Video:
Codec H264
Bitrate 4000 kbps
Language English
Bit Depth 8
CABAC 1
Chroma Subsampling 4:2:0
Color Space yuv
Duration 2:28:07
Frame Rate 23.976 fps
Frame Rate Mode cfr
