I can't get this user agent to show up after dropping it in the plugins folder. Any ideas? Renamed folder to Data18.bundle.
hi cory,
I had the same problem.
Then I deleted the plugin, downloaded again and Restart des Plex-Server Host.
chris
hi cory,
chris
Also I find using the Unsupported App Store makes it much easier to install, update, etc.
chidychi, on 28 Mar 2015 - 8:53 PM, said:hmmm... looks like there are some bugs in the content bundle...
Thanks for working on this. I'd be happy to test any changes/updates.
Hi
I found that the content-bundle works great when you use the ID of the movie / clip. However it does struggle with Scenes from a particular movie
366188 is Monique Alexander in Oil Overload Scene 4 but is not being found... http://www.data18.com/content/366188
Maybe that helps as a hint ?
can you add this metadata agent to the current plex app on readynas 516 or is this just for mac and windows thanks in advance
Hoping for a fix to the manually matching errors soon? I'd be happy to help test or give more examples where it doesn't quite work.
thanks
Bump. chidychi hoping you get some free time to fix the non matching issue.
Would it be interesting to develop a 3rd agent for TV Shows?
A lot of pornographic production comes from web sites and Data18 is built like Matryoshka doll (Network,sites, episodes with date). Lots of dvd studio got a network page on data18 like Evil Angel, New sensations,Wicked pictures etc...And most of the time the first cover the agent download looks like a fanart not a dvd cover.
Somebody tried it but it was for movie series not exactly for website episodes.
Just an idea
@tv.doob - we have something that works (with glitches, though) pretty well EXCEPT for movie scenes - I would love to see this (tiny?) little thing implement first before trying something new. Also, if you use different websites, you have to update a lot more often because the chances that one of the sites changes just a little bit - so you agent for that specific site doesnt work anylonger - are high. The quality of the pictures and the metadata is usually better, though (someone wrote a brazzers agent which works perfect and a NA agent that doesnt work anymore because of some small change).
Actually some problems with Data18content for the release date, year and studio
I can confirm this since the latest Plex update. This plugin no longer is saving the release date, year of release, and studio.
dito :-(
If it helps any. If you want to try your hand at updating the code while you wait for an update to the plugin.
Modifying lines 403 and 409 in ~\Plex Media Server\Plug-ins\Data18-Content.bundle\Contents\Code\__init__.py
Changing (on both lines) "http://www.data18.com/sites/"to "http://www.data18.com/content/" fixed both the studio and collection
This is all I was able to figure out so far. The date seems to be a bit more complicated.
Ok it wasn't so hard: '//p[contains(text(),"Date" look for this string in a text editor (it occurs 3 times) and replace "Date" with "Release". Lines: 78, 166, 225
Data18 updated the layout of their pages which is why this broke.
@Bad Wolf - Thanks, works fine!
Now I wish movie scenes would work with a digital input
Dont understand why 1149373 e.g. isnt working :-(
@Bad Wolf
I made the changes but for some reason the data18-content agent does recognize the title (either actual title or ID) but besides the the title it doesn't grab any of the content ...
Any idea how to fix?
(Data18 (for movies) works just fine and data18-content did work in the past.)
I made the changes to the data18-content bundle, and they worked brilliantly – thank you, Bad Wolf!
Now I'm having issues with the data18 bundle. It finds matches for my movies, but upon matching doesn't download _any_ metadata, including posters and whatnot. Does anyone know of a fix?
The issues only arise when I switch a movie from data18-bundle to data18 in a library that's using the former; when I create a library that uses the latter, it doesn't come up. So I think it might be a Plex issue? Either way, it's odd.
Hey guys I've been working to fix some of the bugs with the agent. This file fixes the date, tagline, studio, and the issue where some actors don't get added to the meta data because of how some of the html on the page isn't consistent. Just replace the python file in the Code folder with this one
file: https://www.dropbox.com/s/sn9q5i1pxgguiu7/__init__.py?dl=0
Hi
Comment out line 144 and 145 and your problem should be resolved. I didn't include that change in my python file because some people might need it. As long as your using the exact movie name or movie ID you should be fine.
Just tried it out and it works
You are my HERO! Where can I donate? Finally! Thanks a billion times!
Just two smaller things: I'd like a possibility to auto-remove things like "Heterosexual", "Hardcore", etc. from the metadata, and see more than two tags in the detailed view. But thats really just a smaller thing.
