Hey all, first of all thank you for tackling this problem. I'm a newb to plex and media servers in general. I'm just trying to get my adult content indexed and seems like this is the best way. Here's what I've done
Installed Plex, Installed Unsupported appstore, installed data18content, data18. Renamed all my scenes to exactly what data18 calls them. Added a folder to my library and under "advanced" checked it to scan under data18content for the scraper. My problem is very few work.
Bonnie Rotten in ■■■■ Required - Scene 1
Bonnie Rotten in Evil ■■■■ 21 - Scene 1
Bonnie Rotten in Hot Body Ink 1 - Scene 1
Bonnie Rotten in Massive Facials 6 - Scene 5
Bonnie Rotten in Naughty Rich ■■■ - --------------- Actually worked!
Bonnie Rotten in Squirt Gasms - Scene 1
Thats how my files are named, and only 1 worked. I spent the time and just copied and pasted the titles from data18 so I think the titles are right. I've got another Stoya folder and not a single one worked.
You are my HERO! Where can I donate? Finally! Thanks a billion times!
Just two smaller things: I'd like a possibility to auto-remove things like "Heterosexual", "Hardcore", etc. from the metadata, and see more than two tags in the detailed view. But thats really just a smaller thing.
Hi sorry for the late response I was thinking this thread was dead so I never checked. But to answer you last question go to line 371. To filter Heterosexual paste this after None " and re.match(r'Heterosexual', genreName) is None" so the line should now look like this after "if re.match(r'Filter content by multiple tags', genreName) is None and re.match(r'Heterosexual', genreName) is None:". To filter Hardcore paste the same code after None again and replace r'Heterosexual' to r'Hardcore'.
thanks, works perfect! If you are working on that - now it is almost perfect :-)
Does know how to search by number/data18 id? I don't know where to put that number in plex.
I already wrote: You have to edit the code of the plugin and remove the two lines teda1 posted on page 10 of this thread. Otherwise, searching for movie scenes does not work by number. You then can either rename the movie to the ID (for automatic matching) or enter it in "fix incorrect match".
I’ve downloaded your code and it work very well when entering the ID, but i get no results by title.
The Lines 144+145 aren’t delete. What can i try to fix it?
For me the Plugin stopped working at all… No results being found any more… tried changing /sites/ to /content/, tried #ing lines 144 and 145, tried title name, tried contentid… i am simly getting no results… :((
All, not sure what the issue with the posters is, I haven’t had any issues lately (With Movies or Content)
However a series of updates fixing actors, years, “in” in the title of the content, being able to search for the content ID directly, and other fixes have been applied and pushed up to the Content Plugin.
Thanks to chidichy for letting me access to that repo.
I’ll keep making updates as much as I can. This latest update has been working very well with me
I will note I have seen data18 blocking my IP address from time to time so I have had to resort to using a VPN from time to time, I see this mainly when I search on the site and get no results.
Not sure if anyone else is having that problem but just something to be wary of
halkon: works nice, seems to be one problem for me with the date
Scene Information Release date: July 19, 2015 - does work
Scene Information Release date: May, 2015 Movie Release - does not work
@halkon: Thank you for making this usable again! Unfortunately data18 decided to stop updating content from various sites like sexart, joymii, nubiles… Hopefully there will be an alternative anytime soon… Blocking happens to me too btw. This seems to happen when plex tries matching my catalogue too often, since maybe only half of it could be matched… I had to change the settings for this library to personal media and then manually do the search for the content which I know is in their db…
Another question: Sometimes it catches the information for actors and sometimes it doesn’t… even for the same studio…
Furthermore: Would it be possible to also have the release date displayed in the search results, like this agent used to at some point?
