[adult] data18.com Metadata Agent - Release
OLD question (solved):
having another problem now. The content agent works great, except for 1 "series".
http://www.data18.com/content/1136139 (all POVD series).
If you try to search on data18.com you don't find it either, neither does the content agent.
Can someone look into that? If I can provide any more information please let me know.
OK, solved my problem. Didn't see the N.A. site problem you described on page 4. Is there really no other chance or site which can do this better, maybe with an API?
Antoher request would be, if this agent has any solution to search for the content ID. The anidb.net plugin from the forum here has this search (you just type aid:XXX (XXX=ID)). Maybe someone can use this plugin to implement it here?
Best regards
I'm getting several incorrect matches with the Data18 agent. It downloads a low-res cover only and it sets an incorrect title and description.
did you try to use "fix incorrect match". Did you find the correct one there?
To make to auto discovery working you need very exact filenames (TITLE (YEAR).xxx)). Maybe the title is used a number of times.
It finds the correct match, but for some reason the title it imports doesn't match when it is imported, even when trying to fix the incorrect match.
Like I said, the cover is imported (at low res), but the title/description are for totally different titles.
Hello,
I have the same troubles, even if i use "fix incorrect match". It finds the correct match, but imports metadata from another movie
it seems to include only movies of 2014.
I dont have any idea how to resolve this problem.
If someone have an idea...
TY
Hi
I have the same thing happening but for any movie has nothing todo with the release date. Very strange behaviour. Anybody has any idea ?
I am have the same issue as well. Agent finds correct version after "fixing incorrect version" and then replaces it with the wrong thing. I cant find any metadata on the file that would indicate the incorrect version as well.
It sounds like the site may have changed again. I’ll try to take a look at this in the next few days.
The problem is the page "number" associated with newer titles.  The metadata agent takes the URL for the movie page and places it in the "Tagline" field, but appears to expect only a 6-digit number.  The newer movies have 7 digits and the agent is stripping off the last number, leaving a reference to a different movie.
@welteraj thanks, can this be fixed ?
Please fix this agent und perhaps with trailer support...
Blaresteep made an update to address this problem. Please pull the update from the unofficial appstore and let us know if it’s fixed. Cheers
Seems to be working for me. Make sure you uninstall it and then re-install the addon. I had to delete the library and re-add it as well but others might not have that issue. Thanks for the fix and update!
At this moment I tried to rescann and it gave me the wrong posters (split front and back) for Evil Angel & Jules Jordan Labels
Hey are the right posters downloaded at all? If you edit the entry and choose a new poster is it in there?
Yes they are being downloaded but not selected. It can be done manually but the library is 500+ titles so it is a bit cumbersome.
Found a problem but it's slightly more related to the scanner not the metadata agent. Relevant info for anyone who wants a "fix" though. The default movie scanner sees the string 'xxx' as a miscellaneous tag to be removed during matching titles. I happened to have quite a few parody titles which used that in their name.
Ex:
The ■■■ Files a Dark XXX Parody (2009)
The scanner however will match the title as 'The ■■■ Files a Dark Parody', which you would think wouldn't be a big deal. However when data18 attempts to find the metadata for it, it will use the url:
http://www.data18.com/search/?k=The+■■■+Files+a+Dark+Parody&t=0
Which will come up with zero hits. If you add back in the XXX
http://www.data18.com/search/?k=The+■■■+Files+a+Dark+XXX+Parody&t=0
No problemo. My hack'ish solution was to re-implement the default Movie scanner but leave the XXX string alone. This actually happens inside VideoFiles, which is used by Movie Scanner in the CleanName function. Mostly copy'pasting and changing the usage of VideoFiles.CleanName to just CleanName (because it will be defined locally in the script).
So if you have a title that REQUIRES the string 'XXX' in the title to be matched correctly, you'll have to use another scanner.
Another way to achieve a similar result would be to name your file “the ■■■ files a dark”. Data 18 searching does well with search terms that contain the result. This of course gets difficult with popular words, or search terms containing few words.
Yeah I had actually considered that at first...but a lot of the other titles started turning into garbage :3
Figured it was easier to just change the scanner, since the porn is in its own category anyways.
The Data18-content agent does not seem to find movies scenes any longer (at least for me, after it worked well for a long time). Is ti maybe related to the change that the Data18 agent for movies needed? Could someone look into it, please? I also like the idea from justmultiplex to simply add/search the data18 content id so I can manually add stuff as fallback.
