None of my adult films are matching! I have adult films selected in the the Movie Database selected and have the AdultFilmDB.bundle installed. No joy even with very famous titles for example Debbie Does Dallas or Deep Throat. They have the correct release years and names. I can even find some of them in the IMDB though a direct search does not find them a Google search does.
I too find this can be challenging, some movies will automatically populate the information while others do not. I have two methods for handling this: 1) Run the fix match or 2) manually add the information.
It would be nice to have a scanner that scans against an adult database. I know there are other products, similar to PLEX where users load a master database and only have a small copy of that database, just the movies they have.
Brad
You guys might want to try the ExcaliburFilms.bundle or the data18.bundle as your Agent.
You would use the regular movie scanner.
