Server Version#: 1.24.5.5173
Player Version#: 4.70.0
I’m not able to find where the logs would be for this problem. I cleared them all out, and the Plugin Caches, then retried the issue and found nothing remotely close in the few logs it generated, and no Caches rebuilt.
Issue:
Lets say my file is:
H:\Multimedia\Adult Films\Threesome Fantasies 6 (2019) {tmdb-630512}\Threesome Fantasies 6 (2019) {tmdb-630512}.mkv (I’ve also tried without the {tmdb} tag in both places)
Plex doesn’t match it automatically, so I go to manually Match it, but a whole bunch of them come up, but not #6, so I can’t manually match it. If I do a manual search on the Match page, no matter what I put in, I can’t get it to find it.
If I Manually search for “tmdb-630512”, No Matches Found. If I search for “tmdb-680”, Pulp Fiction comes up, which shows the search is working. I’m able to search for “tmdb-725066” the correct adult film shows up, showing it’s not an adult-only issue.
Anything I can do to match this media? Same with tmdb-640061 and tmdb-687773, can’t find either.
