Advanced show edit
Hi! how can i enable Advanced tab?
Server Version#: 1.21.2.3918
Nothing to be enabled. The advanced tab should be available on the tv-show level in a tv-show library for all shows of your own server.
now I can see it. may be I was looking in season, not the show. Thanks!
I’m trying to fix episodes order in Star Wars Rebels S01, but changing episode order in advanced isn’t helping (((
You’ll need to refresh the metadata after changing the order in the advanced show settings.
