Lost Advanced Tab when editing Shows
Server Version#:
I just installed the latest update and I’m not sure if that changed things, but I recently had to remove the show Firefly from my library and re-add it. Which of course means that I need to edit the show to force the DVD order of episodes. Previously I went to the advanced tab on the show and changed episode order to TVDB(DVD) and this of course fixed it. However this time when I went to edit the show there was no Advanced tab. Editing the whole folder “TV Shows” gives me access to an advanced tab but only 2 options for episode ordering: TVDB or The Movie Database. Did the update change how this edit is made? Or have I done something stupid to “lose” access to this function? Any help would be appreciated. Thanks!
make sure you are editing the show and not the season.
Thank you so much! That was it.
I was trying to edit the show from the Recently Added list which was short cutting to the season’s edit menu. Selecting the show after moving to the Library tab allowed me to edit the show as desired.
Thanks again!
