After last server update, PROBLEM!
After last server update, my plex pc server is unreachable when i open it in my pc browser. I changed nothing other than update. When i open it, its unteachable then it is able to reach the server pc and intermittently thereafter. What did you do Plex? I’m totally a newbie in this thing. Thanks!
having same sort of problems, started yesterday, on the PC using Firefox or any other browser,i can get the plex hub "home screen"but if i try and play anything the plex player just stalls, just waiting to load but if i use my Roku on WiFi it works fine.
And before you say try another PC, i tried on 3 different one’s, all the same prob, even not playing on the server pc but only on the Roku .
tried all kind of settings but nothing woks
no idea
just getting a lot of errors on console if i try and play anything on a pc but not the Roku
[Transcoder] [h264 @ 007ddc40] Failed loading nvcuvid.
[Transcoder] [h264 @ 007ddc40] Cannot load cuvidGetDecodeStatus
[Transcoder] [h264 @ 007ddc40] Failed setup for format cuda: hwaccel initialisation returned error.
Couldn’t find the file to stream: F:\plex transcoder\Transcode\Sessions\plex-transcode-c4z4z8xuediqqdckd7n9mwzc-bd5ee14a-77c8-4d96-bbe1-b9de8c2c8394\init-stream0.m4s,F:\plex transcoder\Transcode\Sessions\plex-transcode-c4z4z8xuediqqdckd7n9mwzc-bd5ee14a-77c8-4d96-bbe1-b9de8c2c8394\chunk-stream0-00001.m4s
Transcoder: Failed to delete session directory (boost::filesystem::remove: Access is denied: “F:\plex transcoder\Transcode\Sessions\plex-transcode-wqk0ndv4ofhlmo9do84qc6uk-b2acd213-b43f-4be1-9575-800ce7d17df9\chunk-stream0-00024.m4s.tmp”)
and the list goes on
Same problem here. Plex server is running at 100% cpu as well.
same here just of late amd 6 core maxed out most of the time sometimes lagging because of it too
just applyed the new patch and still no joy
Windows 7 SP1 or newer
1.18.0.1944-f2cae8d6b
October 11, 2019
tryed the 1.18.0.1913 this morning and now this new one still the same but still works on the Roku strange
Is the team aware of this problem already? I hope this gets fixed on the next update.
Updated to the latest version of the server, problem not resolved still… developers, please don’t ignore this problem. Thanks!
