The last update seemed to fix the problem of syncing to iPad or iPhone not appearing under Home only under Sync itself. Hence they wouldn’t play. Now since the latest update 2 days ago the problem is back. Trying to sync a series to mynipad and it’s working but not appearing under browse or discover. Only under sync. So won’t load unless you do a search and run it from there. Not how it’s supposed to work. So frustrating as we are off on a three month motorhome holiday and want to put a load of shows on the iPad. Question is. Why is it not working. AGAIN.
Fixed it. Log out on the iOS Device then log back in. That fixed it.
