AgentsCheck Box
Server Version#:1.13.5.5332
I go to Server/Agents and check the blocks for agents I want to enable When I move from that screen the checks disappear. There is no save button on the Agents screen – how do I get my changes to stick?
Use a different web browser.
Or disable browser add-ons which filter out content from websites like AdBlock, uBlock, NoScript etc pp.
I hope you are not talking about a Plex Cloud server however. There, this behaviour is normal.
I was speaking about the basic PMS server, located on a local computer using local resources.
After posting the message, I rebooted my entire system stem to stern and then restarted. At that point I was able to get the checkmark stick.
So I will write this off as an IFM, unless it happens again.
Thank you for responding so promptly.
