AirPlay not working
I have actually a problem with my raspberry pi Model B. I have installed the rasplex system, and activate the airplay. But it's not detected on my iPhone and iPad. The raspberry is connected to Ethernet, and sometimes it is detected by my iPhone, but it's extremely rare.
Do you know this problem ? I'm on Numericable, I have a Netgear Gateway.
Thanks and Regards,
RedwinX
This is probably a networking issue. You should recheck your routers multicast settings (Multicast is required).
Thx for your answer, The problem is due to my routers. It doesn't support multicast, so I have buy a new router and it's working.
Regards,
RedwinX
