It did work for me as well ! Thanks a lot for this one
This is really amazing PascalW !
Thank you SO much for this, I canât wait to show how cool and easy it is to my friends
Unfortunately not - yet?
I doubt it will ever come into Airplay because it is encrypted.
But the video is just amazing. I tried the standalone airplayer app from Erica Sadun.
How can I uninstall anything this script installed?
Thanks for the kind words guys.
Unfortunately audio streaming indeed is not supported and Iâm afraid that might never be since, as dawiinci pointed out, is encrypted and hasnât been cracked yet afaik.
Run this:
<br />
pip uninstall -r path/to/requirements.txt<br />
I have it working perfectly until I close the Terminal.
Could someone explain this command and how I should run it.
chmod +x airplayer.py
Thanks for helping a dummy out
I think this is because of the codec (or what its named) to airport express/appleTV. Same issue with AirFoil, but not from iTunes.
Same problem here, i'm a Terminal newb. But, Airplay works, many thanks for this great feature!
I hope someone will crack the audio-only feature and then it will be perfect for my setup.
in terminal, "cd" to the place you have the file airplay.py and do "chmod +x airplayer.py".
If you have done all the points, then you can restart your Mac, start Plex and enjoy AirPlay !
I used the Airplayer from Erica Sadun and it worked without any stuttering or repeating at the start. I don't know how they are related to each other but if one can do it...
Or it is a problem with Plex, maybe the caching is too short and it loops.
Thank you for your help. its working perfectly now.
Amazing work and great documentation! It works pretty well for me.
So sending YouTube clips over works⊠what are the other apps that should be able to have this functionality? I have tried sending over an iTunes short film but it seemed to have stalled.
I tried a video from iTunes. It works.
You can try Airplayer directly from Erica Sadun. It works great without Plex. It's just an App so you don't have to install anything.
http://ericasadun.com/ftp/AirPlay/
PascalW,
is your script based upon the same source as Erica Saduns Airplayer? If so, she made a lot of updates maybe we can benefit of this work.
Anything else - even pausing on Plex works great. It's really just the initiation of the movie. It repeats the first 0.7s for about four times before it plays smoothly. I tested from an iPod touch and it doesn't matter from which app or if the media is local or not.
This doesn't happen on the Airplayer app from the link above. Could this be an issue with caching in Plex? Maybe the stream can wait another second before it shows the movie to cache a bit more. I pushed the Plex cache to 10s but it had no effect.
Ah I think I know what my problem seems to be. I canât play DRMâed content that I bought on iTunes from my iPhone to the Airplay plugin for Plex. Podcast downloaded videos from my local PBS station work fine. Some Pixar animated short films do not, they seem to start streaming and playing but never take over the Plex screen. Probably an issue not easily solved, which is why I believe Erica Sadunâs Airplayer app has to launch these same DRMâed videos in QuickTime.
I just tried to get an app (Live TV) working with AirVideoEnabler. It doesnât play. Did anyone already try that? It could also be an issue of the plugin.
I cant get it to work for me, it says something about pybonjoru or something? can anyone help me?
Did you read the installation instructions? You need to install a few python dependencies, see https://github.com/PascalW/Airplayer/blob/master/INSTALL.mdown.
Read the installation procedure !!
Execute âsudo pip install -r requirements.txtâ, this will install the required python packages. If you get âbash: pip: command not foundâ then first execute âsudo easy_install pipâ.
Just thought Iâd post a quick âthank youâ â this worked great!
(after I figured out how to install pip, that isâŠ
Can someone explain to me how I get this to run automatically on startup?
PascalW updated the instructions. You can find it here:
PascalW, do you have an idea how to fix the stuttering in the beginning? This is very uncommon to Airplay and even to Airplayer from Erica Sadun. So I guess the issue lies in the transformation to Plex. It seems it doesn't happen on photo streams. Maybe it is related to the audio.
