Can’t get Airplay to work. OPTH shows up under devices to stream to in iOS but there is no sound though the audio seems to stream.
It is not working for me either.
This has been an issue since IOS8 I think with the built in airplay receiver. Try using something like shairport4w if you’re running on Windows instead, it’s a stand alone airplay receiver that works well for audio and it’s free.
Windows is not a option. I have however bought a similar app to OS X called Airserver that does the work for now. It would be great though if the issue gets a fix under the OPHT teams development since it as you said has been broken for a long time on PHT. Everything in the same application is nice ![]()
Not that simple, libshairplay is the issue, which is an open source project, once that is fixed for iOS7/8/9 then it will solve the issue. I still have an iPhone with iOS6 which works without a problem.
The source of the problem is Apple continually changing the way AirPlay works.
