Allow insecure connection only on local network
Server Version#:4.33.1
I have secure connections required in Plex, but this is causing issues on my local network with my LG TV. On my TV, I set to always allow insecure connection, but it looks to be forced on the server side.
This results in there being a minute of ‘something went wrong’ when starting the Plex app on the TV, until the Plex app ends up connecting via a secured connection. Everything works as expected when I desable secured connection on the server side.
Is there any way of allowing insecure connections for the local network on the server while have secured connection set to ‘required’. Essentially, creating a white list?
Thanks!
I’m not sure if this works when you have PMS set to “required”, but you can give it a shot.
