Allwinner h6 box can’t seem to load Plex
Server Version#:
Player Version
I got this new box and it’s running in allwinner H6 chipset.
And the Google play store doesn’t work on it yet because I guess it’s not compatible they said it would be middle of February before Google releases an update. So I want Plex I’ve tried to install side loading Plex from a PK pure and another a PK site but I either get it trying to install and then it just says app not installed. Or I get trouble parsing package.
I didn’t know if Plex didn’t work on this chipset or if it really matters.
Try downloading direct from the Plex for Android announcement thread.
I believe you want the arm64v8a version. According to this site, the H6 has Cortex A53 cores, which per ARM, is v8a architecture.
I’ve no idea if the lack of the Google Play Store will hinder the ability to run the Plex app.
It is possible to sideload Google Play Store on Amazon devices (link). It might work for your box as well.
That app after downloading gives me the same error all I get is it starts to install and then it says app not installed.
