Alphabetical links missing?
Server Version#: 1.21.1.3753
Player Version#: 4.43.4
If I remember correct, there used to be an alphabetical column from A to Z at the right side of the display where you could click on a letter and scroll to the movies or TV shows that started with that letter but it seems to have disappeared.
It is still there. But you need to
  • have “enough” movies in the library
  • the library view needs to be sorted by “Title”
Thanks, @OttoKerner
Perfect.
I believe I changed the Movies library sorting options to “By Date Added” and therefore the links were not there. Sorting by “Title” solves it.
