Just realised from above I need the beta release but even with pass toggled I don’t have the option to download it for windows
It’s right on the server download page…
https://www.plex.tv/media-server-downloads/?cat=computer&plat=windows
I’ve you’ve set the server update channel in your server settings to Beta, it’ll probably take until Plex does its next regular update check.
No need to be rude, I wouldn’t show up when I first looked, had to use a different browser
My apologies if you perceived my response as rude… though I’m not sure which part offended you. In anyway… no offense intended.
Using ‘…’ is rude, and grammatically incorrect.
I cannot get the alternate or Netflix option to show up for money heist for the life of me. I’m on the latest beta as of today, have refreshed meta for the show, unmatched/rematched, using the Plex TV series agent, but only aired, DVD or absolute options show up for me.
Just tried this out on Animaniacs and it worked like a charm. One piece of advice for anyone who runs into the same issue I did, is if the new sort orders aren’t displaying on the show, make sure it is matched. I had left a few unmatched so metadata wouldn’t ever update, and the new sort options wouldn’t show until I matched them again. I’m assuming this is because each show can have differently named alternate sort orders.
Precisely.
