TVDB alternate dvd order
Server Version#: 4.126.1
For Batman: The Animated series on the Blu-Ray order tab it says “Usable as “Alternate DVD Order” in API-connected systems.”
This isnt one of the options under Episode ordering. Am I out of luck and needing to rename and or manually add the metadata to the episodes?
This isn’t supported at the moment but there’s a related feature suggestion.
Thanks.
