"An attempt was made to access a socket in a way forbidden by its access permissions"
Hi, I just updated my ATV3.  I installed a profile on my Apple TV but I'm struggling to get the PlexConnect server to start without an error.  Here's my log:
21:33:56 PlexConnect: ***
21:33:56 PlexConnect: PlexConnect
21:33:56 PlexConnect: Press CTRL-C to shut down.
21:33:56 PlexConnect: started: 21:33:56
21:33:56 PlexConnect: IP_self: 192.168.1.78
21:33:56 DNSServer: started: 21:33:56
21:33:56 DNSServer: ***
21:33:56 DNSServer: DNSServer: Serving DNS on 192.168.1.78 port 53.
21:33:56 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.
168.1.78
21:33:56 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
21:33:56 DNSServer: forward other to higher level DNS: 8.8.8.8
21:33:57 WebServer: started: 21:33:57
21:33:57 WebServer: ***
21:33:57 WebServer: WebServer: Serving HTTP on 192.168.1.78 port 80.
21:33:57 PlexGDM: ***
21:33:57 PlexGDM: looking up Plex Media Server
21:33:57 WebServer: Failed to connect to HTTPS on 192.168.1.78 port 443: [Errno
10013] An attempt was made to access a socket in a way forbidden by its access p
ermissions
21:33:57 PlexConnect: WebServer_SSL not alive. Shutting down.
21:33:57 PlexConnect: Shutting down.
21:33:58 PlexGDM: servers discovered: 1
21:33:58 XMLConverter: PlexGDM - PMS: 192.168.1.78:32400
21:33:58 WebServer: Shutting down.
21:34:01 DNSServer: Shutting down.
21:34:01 PlexConnect: shutdown
Any idea what I'm doing wrong?  I've put the trailers.pem certificate I made in the folder, updated Python and downloaded the newest version of PlexConnect.
OK I just figured this out, so if anyone finds it by Googling or whatever; use netstat - ano in the command prompt and find out if any process is using port 443.  I have VMWare installed on my PC and it was using the port, stopping PlexConnect from doing so.
Thanks for the info TheGreatDave. I also have VMware on my Windows 8 PC and it was using port 443 for the "share VM" feature. PlexConnect working perfectly now!
