Plex connetc not starting application.js atv3
After starting plex connect I get "Trailers not available..."  And looking at the log and the window, nothing happens after the intercept request.  I have also tried running python from a batch as administrator and I get the same results.
I have taken everything down to factory and reinstalled everything but I am at a loss why the application is not starting.  Any help would be awesome, I have read about every form I could find
  • Apple TV 3 firmware 6.0 (6646.65)
  • DNS 192.168.0.196
  • Plexconnect is on a Windows 7 (64bit) :core i7 3.4 ghz
  • Plex connect ip 192.168.0.196
  • PMS on same system 192.168.0.196 ver 9.8.6
  • PMS on local machine 192.168.0.196
  • Plex connect version 0.2 as of 10/22/2013
  • settings.cfg
  • [PlexConnect]
    enable_webserver_ssl = True
    logpath = .
    enable_dnsserver = True
    prevent_atv_update = True
    port_dnsserver = 53
    enable_plexconnect_autodetect = True
    port_pms = 32400
    port_webserver = 80
    ip_plexconnect = 0.0.0.0
    certfile = C:\PlexConnect-master\assets\certificates railers.pem
    ip_dnsmaster = 8.8.8.8
    loglevel = High
    ip_pms = 192.168.0.196
    enable_plexgdm = True
    port_ssl = 443
    trailers cert installed good until 10/17/2033
    05:40:58 PlexConnect: started: 05:40:58
    05:40:58 Settings: getsetting enable_plexconnect_autodetect=True
    05:40:58 PlexConnect: IP_self: 192.168.0.196
    05:40:58 Settings: getsetting enable_dnsserver=True
    05:40:58 DNSServer: started: 05:40:58
    05:40:58 Settings: getsetting port_dnsserver=53
    05:40:58 Settings: getsetting ip_dnsmaster=8.8.8.8
    05:40:58 DNSServer: Failed to create socket on UDP port 53: [Errno 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted
    05:40:58 Settings: getsetting enable_webserver_ssl=True
    05:40:58 WebServer: started: 05:40:58
    05:40:58 Settings: getsetting port_webserver=80
    05:40:58 WebServer: ***
    05:40:58 WebServer: WebServer: Serving HTTP on 192.168.0.196 port 80.
    05:40:58 ATVSettings: init class CATVSettings
    05:40:58 ATVSettings: load settings
    05:40:58 Settings: getsetting enable_plexgdm=True
    05:40:58 PlexAPI: ***
    05:40:58 PlexAPI: looking up Plex Media Server
    05:40:58 PlexAPI: Sending discovery message: M-SEARCH * HTTP/1.0
    05:40:58 PlexAPI: Received data from ('192.168.0.196', 32414)
    05:40:58 PlexAPI: Data received:
     HTTP/1.0 200 OK
    Content-Type: plex/media-server
    Resource-Identifier: b7d47198110e399905d4caa812234f7c35e01ae6
    Port: 32400
    Updated-At: 1382430290
    Version: 0.9.8.6.175-88ffbb2
    05:40:58 Settings: getsetting port_ssl=443
    05:40:58 Settings: getsetting certfile=C:\PlexConnect-master\assets\certificates railers.pem
    05:40:58 WebServer: WebServer: Serving HTTPS on 192.168.0.196 port 443.
    05:40:59 PlexAPI: servers discovered: 1
    05:40:59 PlexAPI: Brown Cinema 192.168.0.196:32400
    05:40:59 XMLConverter: PlexGDM - PMS: 192.168.0.196:32400
    05:40:59 ATVSettings: setOption: update pms_uuid to ('b7d47198110e399905d4caa812234f7c35e01ae6',)
    05:41:12 DNSServer: DNS request received!
    05:41:12 DNSServer: Source: ('192.168.0.199', 64318)
    05:41:12 DNSServer: Domain: trailers.apple.com
    05:41:12 DNSServer: ***intercept request
    05:41:12 DNSServer: -> DNS response: 192.168.0.196
    05:41:20 PlexConnect: Shutting down.
    05:41:20 WebServer: Shutting down.
    05:41:20 ATVSettings: save settings
    05:41:20 PlexConnect: shutdown
  • :"JB
You have an error with regards to your DNS port.
Do you have something else running on port 53 (or maybe plexconnect did my shut down correctly check for running python processes)
  1. Drewbie wow I must have glossed over that line.  Well just in case I manually opened the port but still no joy, here is the new log
19:04:46 PlexConnect: started: 19:04:46
19:04:46 Settings: getsetting enable_plexconnect_autodetect=True
19:04:53 PlexConnect: IP_self: 192.168.0.196
19:04:53 Settings: getsetting enable_dnsserver=True
19:04:53 DNSServer: started: 19:04:53
19:04:53 Settings: getsetting port_dnsserver=53
19:04:53 Settings: getsetting ip_dnsmaster=8.8.8.8
19:04:53 Settings: getsetting prevent_atv_update=True
19:04:53 DNSServer: ***
19:04:53 DNSServer: DNSServer: Serving DNS on 192.168.0.196 port 53.
19:04:53 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.196
19:04:53 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
19:04:53 DNSServer: forward other to higher level DNS: 8.8.8.8
19:04:53 WebServer: started: 19:04:53
19:04:53 Settings: getsetting port_webserver=80
19:04:53 Settings: getsetting enable_webserver_ssl=True
19:04:53 WebServer: ***
19:04:53 WebServer: WebServer: Serving HTTP on 192.168.0.196 port 80.
19:04:53 ATVSettings: init class CATVSettings
19:04:53 ATVSettings: load settings
19:04:53 Settings: getsetting enable_plexgdm=True
19:04:53 PlexAPI: ***
19:04:53 PlexAPI: looking up Plex Media Server
19:04:53 PlexAPI: Sending discovery message: M-SEARCH * HTTP/1.0
19:04:53 PlexAPI: Received data from ('192.168.0.196', 32414)
19:04:53 PlexAPI: Data received:
 HTTP/1.0 200 OK
Port: 32400
Updated-At: 1382568598
19:04:53 Settings: getsetting port_ssl=443
19:04:53 Settings: getsetting certfile=C:\PlexConnect-master\assets\certificates railers.pem
19:04:53 WebServer: WebServer: Serving HTTPS on 192.168.0.196 port 443.
19:04:54 PlexAPI: servers discovered: 1
19:04:54 PlexAPI: Brown Cinema 192.168.0.196:32400
19:04:54 XMLConverter: PlexGDM - PMS: 192.168.0.196:32400
19:04:54 ATVSettings: setOption: update pms_uuid to ('b7d47198110e399905d4caa812234f7c35e01ae6',)
19:05:01 DNSServer: DNS request received!
19:05:01 DNSServer: Source: ('192.168.0.199', 57125)
19:05:01 DNSServer: Domain: time.apple.com
19:05:01 DNSServer: ***forward request
19:05:01 DNSServer: -> DNS response from higher level
19:05:12 DNSServer: DNS request received!
19:05:12 DNSServer: Source: ('192.168.0.199', 62453)
19:05:12 DNSServer: Domain: init.itunes.apple.com
19:05:12 DNSServer: ***forward request
19:05:12 DNSServer: -> DNS response from higher level
19:05:14 DNSServer: DNS request received!
19:05:14 DNSServer: Source: ('192.168.0.199', 61375)
19:05:14 DNSServer: Domain: itunes.apple.com
19:05:14 DNSServer: ***forward request
19:05:14 DNSServer: -> DNS response from higher level
19:05:14 DNSServer: Source: ('192.168.0.199', 62644)
19:05:14 DNSServer: Domain: configuration.apple.com
19:05:14 DNSServer: Source: ('192.168.0.199', 57156)
19:05:14 DNSServer: Domain: e673.g.akamaiedge.net
19:05:14 DNSServer: Source: ('192.168.0.199', 52050)
19:05:14 DNSServer: Domain: xp.apple.com
19:05:25 DNSServer: DNS request received!
19:05:25 DNSServer: Source: ('192.168.0.199', 61132)
19:05:25 DNSServer: Domain: trailers.apple.com
19:05:25 DNSServer: ***intercept request
19:05:25 DNSServer: -> DNS response: 192.168.0.196
19:05:34 PlexConnect: Shutting down.
19:05:35 DNSServer: Shutting down.
19:05:35 WebServer: Shutting down.
19:05:35 ATVSettings: save settings
19:05:35 PlexConnect: shutdown
What version of Python are you using?
Is that the log file or the terminal window content?
I am using 2.75 and it is the log file  (set to high)
