Server Version#: 1.18.7.2457-77cb9455c
Player Version#: Not detectable. It is the latest version I can get through the play store on my Mi Box S
Hey there!
I have an issue with Plex I just started using. I want to play movies and series from two different Synology DiskStations. All that works absolutely fine. However, there are a lot of files that give me an error when I try to start those. In English the error would say something like: An error occured trying to play this item. Please restart server and player.
The weird thing is: In my first room where I have set up a TV with a Mi Box S it works just fine. Another TV in the same network running with a managed Plex user, and also with a Mi Box S won’t start most of the movies.
I am not 100% sure but I tend to think it has something to do with DTS Audio. As far as I know the Mi Box S supports DTS audio.
Heres the media info of one of the files, if this helps.
<Media id="1058" duration="6746496" bitrate="8345" width="1280" height="528" aspectRatio="2.35" audioChannels="6" audioCodec="dca" videoCodec="h264" videoResolution="720" container="mkv" videoFrameRate="24p" audioProfile="dts" videoProfile="high">
<Part accessible="1" exists="1" id="1058" key="/library/parts/1058/1224878856/file.mkv" duration="6746496" file="/volume1/Filme/Zimmer 1408.mkv" size="7037417932" audioProfile="dts" container="mkv" videoProfile="high">
<Stream id="32730" streamType="1" default="1" codec="h264" index="0" bitrate="5273" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" codedHeight="528" codedWidth="1280" frameRate="23.976" hasScalingMatrix="0" height="528" level="41" profile="high" refFrames="5" scanType="progressive" width="1280" displayTitle="720p (H.264)"/>
<Stream id="32731" streamType="2" selected="1" default="1" codec="dca" index="1" channels="6" bitrate="1536" language="Deutsch" languageCode="ger" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" samplingRate="48000" displayTitle="Deutsch (DTS 5.1)"/>
<Stream id="32732" streamType="2" codec="dca" index="2" channels="6" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="16" profile="dts" samplingRate="48000" displayTitle="English (DTS 5.1)"/>
<Stream id="32733" streamType="3" default="1" codec="srt" index="3" language="Deutsch" languageCode="ger" title="German Forced" displayTitle="Deutsch (SRT)"/>
<Stream id="32734" streamType="3" codec="srt" index="4" language="Deutsch" languageCode="ger" title="German" displayTitle="Deutsch (SRT)"/>
</Part>
</Media>
Thanks a lot for any help! I really wanted to use plex and not that DSVideo anymore…
