Hey all.
I’m using an online server with Plex installed that allows mounting of Amazon Cloud Drive. When I add TV Shows, Plex isn’t analyzing all the Media. Its getting so far and then just seems to stop…possibly timing out and almost certainly when it hits a batch of files that actually DO need analyzing.
However the thread isn’t just about that. According to the Wiki…
https://support.plex.tv/hc/en-us/articles/200289336-Analyze-Media
Half way down it says you can specify multiple items and analyze them. However the button it indicates in the screenshot doesn’t appear in the Web/App.
Am I missing something or
1 Was it removed ?
2 If it was…Why?
3 If it was…Can we at least have the wiki updated please?
The button is there for movies.
It is also there for tv show episodes, if you switch the web app into the ‘episode’ view mode.
If you still can’t see it, you have a ‘zoom’ mode active in your web browser, which you might wanna reset using CTRL+0
Awesome @OttoKerner
I can honestly say In 3 years of Plex I had never even looked at episode view.
