Android 8 Oreo TV/Nvidia Shield Plex Deck
So I just updated to Android 8 Oreo on my Nvidia Shield (which just has plex as a client/app).
They have great integration with Netflix and YouTube now so that you get the strips you’re used to from inside Plex, Netflix, etc can Plex please make that available for Android TV too? So we can have our ‘Plex Deck’ strip direct on the Android TV menus for speedier access and to entise us to play those?
I’ve been waiting for this forever as skipping around between Netflix, Amazon Prime, Plex, YouTube and local TV Channel’s VOD platforms has always been a major headache for me.
Thanks, in advance, guys!
This already exists? Maybe you need to activate it in the android settings somewhere, not sure about that.
That’s great news!
I fiddled about with what YouTube, Netflix, etc showed but Plex wasn’t an option at all, maybe someone can tell me what I’m doing wrong?
I’ll try to post some screenshots later on.
James.
The feature is called “channels” if you search for it in the settings. Not sure where to find it, 'cause I am not at home :slight_smile:
I like the Plex channels on Nvidia shield, but it would be nice to have a channel showing the Live TV… There’s an app called “Live Channels” but it would be good to have it work with Plex only.
