When I try to connect to the PMS server and pull a live channel I get an “An error has occured try again later”.
What does the really mean?
What log will file will tell me?
What am I looking for in the file?
I have PMS running on linux.
thanks in advance
haeffnkr
some errors from the android app
02-10 19:08:03.897 w: [LiveTV] Error or unexpected result calling PMS /tune endpoint.
02-10 19:08:03.899 i: Showing toast: An error has occurred, please try again later
02-10 19:08:04.965 i: [UserAction] Click item Murder, She Baked: A Peach Cobbler Mystery (/tv.plex.providers.epg.onconnect:10/metadata/com%2Egracenote%2Etms%3A%2F%2Fmovie%2FMV008279100000).
02-10 19:08:04.969 i: [LiveTV] About to tune (066)
02-10 19:08:04.970 i: Fetching [method:POST] https://192.168.1.103:32400/livetv/dvrs/10/channels/066/tune?X-Plex-Token=...7Ysn
02-10 19:08:04.989 i: Time out fetching https://192.168.1.103:32400/livetv/dvrs/10/channels/066/tune?X-Plex-Token=...7Ysn.
02-10 19:08:04.990 w: [LiveTV] Error or unexpected result calling PMS /tune endpoint.
02-10 19:08:04.991 i: Showing toast: An error has occurred, please try again later
02-10 19:08:06.452 i: [UserAction] Click item Dodgeball: A True Underdog Story (/tv.plex.providers.epg.onconnect:10/metadata/com%2Egracenote%2Etms%3A%2F%2Fmovie%2FMV001458230000).
02-10 19:08:06.454 i: [LiveTV] About to tune (069)
02-10 19:08:06.456 i: Fetching [method:POST] https://192.168.1.103:32400/livetv/dvrs/10/channels/069/tune?X-Plex-Token=...7Ysn
02-10 19:08:06.476 i: Time out fetching https://192.168.1.103:32400/livetv/dvrs/10/channels/069/tune?X-Plex-Token=...7Ysn.
02-10 19:08:06.476 w: [LiveTV] Error or unexpected result calling PMS /tune endpoint.
02-10 19:08:06.477 i: Showing toast: An error has occurred, please try again later
02-10 19:08:07.253 e: [ServerWebSocket] Websocket error
02-10 19:08:07.255 e: An exception occurred: java.net.ConnectException: failed to connect to /192.168.1.103 (port 32400) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
02-10 19:08:07.261 e: Stacktrace: java.net.ConnectException: failed to connect to /192.168.1.103 (port 32400) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
so… I unselected several of the 600 channels I get from Charter/Spectrum in the dvr line up. The guide on my android phone is pulling up channels that are not part of the selected channels. So as shown above for example… my android is going to the PMS to connect to channel 66 and 69 … but those channels are not selected to be displayed/used by the DVR per the setup in PMS.
So why would the android app display “watch now - live tv shows” that are not what I selected?
BTW - if I select a channel on my android that I did select under the dvr setup on PMS it plays beautifully.
How is this resolved? a config issue or a bug in the code?
thanks haeffnkr
