Android auto - only selected song from album plays
In the current beta (7.24.0.13705-beta), and on at least one earlier, when using over Android Auto only the selected song is being played, after which the background PLEX app closes. I’ve reinstalled earlier beta (7.24.0.13403) and all works ok. Can’t use previous or next buttons as only one item is in the queue.
Hi @adorobis, sorry to hear you’re experiencing problems withe app. In order to investigate it, is there any chance you could share app logs following https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/?
Thanks in advance
Sure, to which e-mail address should I send those logs (as per instructions)?
I have one more observation. It behaves this way only when selecting an album from music synced on the mobile device. If the same album is played from all music the album is played correctly and entire album can be played. Maybe this will help to identify where the bug is. @jesusmc
