Android: New video demuxer for improved playback
So also I could test now once this version.
It really works very well on my Sony TV. Finally all files start.
The only thing I noticed is that every now and then files are transcoded and without reason because they are normal x264 files with AC3/DTS sound. Both supports the TV and even from the same series (same release) it can be that 2 transcoded and 3 are played directly. This is really strange. You would certainly have to look again.
Another problem I noticed is that it hangs when the connection is lost. Sony has the problem that the W-Lan connection is gone every few minutes. With many other streaming apps, this is not a problem and it continues to run because there is a buffer. Your app hangs, however, and always when the buffer is used up, although the connections are partly already 1-2 minutes there again.
Here are my logs of the last 2 days:
Logging Plex Nighty.txt (4,2 MB)
My Nvidia Shield just loaded a new version - 8.30.0.30780, but it still has the issues that were mostly fixed in the 8.29.0.30173-nightly build. Can anyone please provide an update on what version contains what demuxer, and hopefully a pointer to a current build that works better than the released version? Thanks.
v8.29.x.xxxxx is now the stable public channel
v8.30.x.xxxxx is now the testing beta channel
Ok, thanks. But… which of these (if any) has the improved demuxer? I understand that this is complex software, but when using VLC on my Nvidia Shield (connected to the SMB shares) all these videos play perfectly. Has any thought been given to allowing us to substitute VLC for ExoPlayer?
The new demuxer is still a work in progress and is enabled in the beta channel builds. If the new demuxer is still not ready when v8.30.x.xxxxx is released for the stable public channel, it will still only work with the future beta channel builds numbered as v8.31.x.xxxxx.
Are you sure the new demuxer is in the (TV) beta? The release notes indicate that it’s in the mobile beta, but there is no mention of it in the TV beta release notes.
[Mobile] Player: improved demuxer stack for increased performance.
@Gavin-Ashford I stand corrected. Yes it is currently only enabled for Android mobile beta channel. Hopefully once the AndroidTV beta channel reaches v8.32.x.xxxx it will be enabled for all those users.
It fixed my shield 2019 ( tube) frozen picture at start issue. Hope the new demuxer will get into the regular androidtv beta channel. (Is there any way to disable the playbackinfo tech overlay on pause in the nightly? Not a big deal jus curious.)
Is there any further development at all or do testers who have sent feedback and logs also get feedback from the programmers?
It is really questionable how the support at Plex works. You start a test version and then nothing happens for weeks.
I suspect this was a one-off thing to get a few users to help validate some changes. In another thread about Android TV issues, someone from Plex said he was testing internal builds with the new player and seeing good results. Hopefully it will make its way into a beta build soon.
Will you please let us know when it’s in the Android TV beta, and how to become part of that channel? Thanks.
Beta sign ups are done as usual through the Google Play Store.
I think you’re wrong for Android TV. But. I’m already signed up, it seems.
Hi, has this new demuxer been implemented in both the Android mobile and Android TV eg FireTV production released clients?
Above refers…
Yes, but I wondered if the situation had changed at all since then
Seconded. Would really like a way to get notified when the new demuxer is available for Android TV.
Subscribe to beta channel updates. I’m sure they will show when the new player is incorporated.
https://forums.plex.tv/t/release-announcements-android-tv-beta/
Yes I am subscribed but unfortunately from past experience the notes do not always make it clear what is included and more importantly, whats specific to Mobile and Android TV
