Android Q beta crash on connexion
Hi.
I don’t know if I post in the correct place (1st post for me).
The 7.14.0 Android app crashes on connexion screen on Android Q Beta 2 (on a pixel 3 build number QPP2.190228.021). Note that the stable version also crashes on this build…
Yep same issue here, Q Beta 2 on Pixel XL 3
Same here on PXL3 running Qb2.
Crashing on beta 2 on pixel 2 xl as well
from what it sounds like their is no fix to the crashing as of yet.
I wonder if Plex needs to update it’s app or is it just that Android just has a bug that needs to be fixed.
I hope that it’s fixed soon due to I love using Plex on my android and I don’t want to roll back from the beta from Q
Same here, beta 2 pixel 3 XL
It looks like the crashing has been fixed with the latest beta update
Yep, latest update fixes so U can get the main screen and change player to android built-in then works fine
It works!!! Release Announcements - Android TV beta
Thanks for the update!
