Android smart tv
I have a Lenovo server with Ubuntu LTE 20.0 and I have an output bandwidth of 100 MB, before 2022, I could remotely watch 4K movies without cuts, I have 2 4K TVs, a samsung 2015 4K whose version of Plex is from 2018 Since the apps are no longer updated due to obsolescence, I have another 55" TCL TV bought in 2020 and it has an Android TV with the latest Plex apk versions from 2022
From the changes that Plex made in this 2021, I can no longer watch movies that are more than 2 GB on my TCL smart tv, but if on the old samsung with the 2018 app, in the case of the TCL it sends me messages of either I don’t have enough internet bandwidth or my server is very slow. I brought the server to the house and connected it to the local network and still in my TCL smart tv the 4K movies freeze using PLEX, I have PLex Pass, and also add the server with DLNA, if I try to watch 4K movies from PLEX , it freezes, but if I USE VLC accessing the Plex server, they work perfectly, if I use the Media Center app, I can also access the PLEX server and 4K movies work fine. Therefore, I deduce that the problem is the PLEX app for android TV, does it work well for anyone? or as they have corrected it, the solution would be to change the server for one with more capacity but the question is, why accessing the server via VLC works perfectly.
The data of are
Lenovo Server CPUIntel Xeon CPU E23-1226 v3 @ 3.30 GZ x 4, RAM 16 GB, Hard disk 24 TB, OS: Ubuntu 20.04 LTS 64 Bits, Plex version Version 1.26.2.5797
Smart TV TCL Version: V8-R851T02-LF1V634.018640 Kernel version 4.14.76+ Compilation PPR1.180610.011PLex app 9.2.132664 (61b7e466)
Tengo un servidor Lenovo con Ubuntu LTE 20.0 y tengo de salida un ancho de banda de 100 MB, antes de 2022, podia ver remotamente sin cortes peliculas en 4 K, tengo 2 TV 4K, una samsung 2015 4K cuya version de Plex es de 2018 ya que que por obsolecencia ya no se actualizan las app, tengo otra tv TCL de 55" comprada en 2020 y tiene android tv con las ultimas versiones deapk de Plex de 2022
a partir de los cambios que Plex realizo en este 2021, ya no puedo ver peliculas que sean de mas de 2 GBen mi smart tv TCL, pero si en la samsung vieja con app del 2018, En el caso de la TCL me envia mensajes de que o no tengo suficiente ancho de banda de internet o mi servidor es muy lento. Me traje el servidor a la casa y lo conecte a la red local y aun asi en mi smart tv TCL las peliculas 4K se congelan usando PLEX, tengo PLex Pass, y ademas agregue al servidor con DLNA, si trato de ver peliculas 4K de PLex, se congela, pero si USO VLC accesando al servidor de Plex, funcionan perfectamente, si uso la aplicacin Centro Multimedia, tambien puedo accesar el servidor de PLEX y me funcionan bien las peliculas 4K. Por lo tanto deduzco que el problema es la app de PLEX para android TV, a alguien le funciona bien? o como lo han corregido, la solucion seria cambiar el servidor por uno con mas capacidad pero la pregunta es, porque accesando el servidor via VLC Funciona perfecto.
