Android tv box Plex applicantion not working
Newest version is 100% broken on my Android tv box Keeps prompting to go back to Mobile mode or TV layout - and then will crash if you leave it on mobile mode.
Same here. What has gone wrong?
Have you found a solution?
Nope.
The only “solution” has been to use a previous version and stop updates in Play Store.
I have the same problem
How can you use earlier version and stop in play store?
i found a solution i use now VLC for my server it’s working since yesterday
I don’t think your VLC solution will work for me as I share a friend’s server :frowning:
Thanks a lot i removed new version and downloaded older version from Apkpure
