Android TV Player Drop Frames
@“MovieFan.Plex” said:
Hey sorry. Lost track of this thread. Can you check the app settings and see if you have the automatic adjust frame rate setting enabled? Try turning it off, or turn it on if it is off, just to see if there is a difference.
Are you samples still available?
Edit - I didn’t mean frame rate. I meant refresh rate.
Yes Samples are always available. Refresh rate was off, i put it on but it’s the same.
still dropping
