Server Version#: Version 1.29.2.6364
Player Version#: 9.10.1.36024
I started a Tv Show and had the problems that the picture jumped for a fraction every few seconds. Or the image stops very briefly and then jumps further. I don’t know how to describe it exactly but I would have a video of it. The problem is somehow with the Android TV app. I have tested it via the IOS app (Iphone & Ipad) and no problems. So it is also not on the medium itself.
It’s Direct Play. I have also tested it with transcode. Same error here. I don’t have it with other media, so I’ve noticed it now for the first time exclusively with this broadcast.
Are there perhaps already similar experiences?
Thanks for help
A judder every few seconds sounds like a mismatch between the frame rate of the video file and the frame rate of the display.
Try activating “Refresh Rate Switching” in the settings of the Plex app.
I have found a settings which it could be. But has not changed anything. This is called in german “Wiederholrate umschalten”. translates as “switch repetition rate”. Is that the attitude?
