Android TV shows incorrect library names
Server Version#: Version 1.19.4.2865
Player Version#: 8.1.1.18052 (bfeb4ad4)
First this was happening with a different server. and different libraries. So I cleared my data and signed back in, then it occurred with a new server and library.
I have tried clearing app data, cache, uninstalling and reinstalling on the client. Plex Web does not exhibit this problem.
On a different note, it also sees three docker container plex servers as remote servers and doesn’t want to play files at the maximum stream without being manually set to play it that way. The docker containers are on the same network (or at least advertising the same network):
Athena’s Network configuration
This is still occuring with the 8.2
Client Log: client.zip (74.7 KB)
To actually comment, it’s gotten worse and is now affecting more than one server.
This does not occur with plex.tv using a web browser, so fairly certain this is only an issue within the Android TV base. Could anyone comment?
Bump, this is still occurring, and causing a bit of headache, as I have to go through the list of libraries that don’t exist to find the one that is labeled incorrectly.
