Another Error code: 4294967282 Thread
Server Version#: Version 1.41.4.9463
Player Version#: Version 1.108.1.307-dd5b87aa
I couldn’t find solutions in any of the threads so starting a new one.
I updated my server today and started getting these new ‘Error code: 4294967282’ issues where I’d try to play a song and it fails with that error. It seems to only be happening on the Plex Client on my Intel based Mac. The Web player has no issues.
When using the native Mac client, it’ll happily play on the speakers built into my Mac, but when I try to play it out my sound card, the error shows up. When I go to the Audio MIDI setup after I get the error, the audio format selected for my sound card shows an odd Null (shown in screenshot). I have to select a format again for the sound card to work.
Below are some of the things I saw in the logs right after I tried to play a song.
Any suggestions?
Feb 13, 2025 11:14:03.696 [22742588734264] DEBUG - [Req#2e8c/Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/e613bce-97f23d579c1001d8e9cc0d2e-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Transcoder" -analyzeduration 20000000 -probesize 20000000 -i "/data/media/Music/Original_Releases/qobuz/Jimmy Page/Jimmy Page - Live at the Greek (2000) [24B-96kHz]/01. Celebration Day.flac" -map 0:0 -codec:0 copy -copypriorss:0 0 -f segment -segment_format matroska -segment_format_options live=1 -segment_time 1 -segment_header_filename header -segment_start_number 0 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/d60gcp2vu4s6cb6qats8i26p/b8ff7ce4-adb2-461e-8ec9-3318f8cd82ca/manifest?X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_unfinished 1 -segment_list_size 5 -segment_list_separate_stream_times 1 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "chunk-%05d" -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/d60gcp2vu4s6cb6qats8i26p/b8ff7ce4-adb2-461e-8ec9-3318f8cd82ca/progress
Feb 13, 2025 11:14:05.988 [22742511647544] DEBUG - [Req#33ff] Transcoder: Cleaning old transcode directories.
Feb 13, 2025 11:14:05.988 [22742511647544] DEBUG - [Req#33ff] Whacked session kkmi3t9le6mfzmpz4wohhf98, 0 remaining.
Feb 13, 2025 11:14:05.988 [22742511647544] DEBUG - Cleaning directory for session kkmi3t9le6mfzmpz4wohhf98 (/transcode/Transcode/Sessions/plex-transcode-kkmi3t9le6mfzmpz4wohhf98-8724da9e-a139-4043-8194-0cfca0a2d8b8)
Feb 13, 2025 11:14:06.037 [22742625692472] ERROR - [TranscodeOutputStream] Session appears to have died from under us
Feb 13, 2025 11:14:06.042 [22742575119160] DEBUG - Request: [73.222.183.88:41478 (WAN)] GET /library/metadata/1096395?includeMarkers=1 (15 live) #3554 GZIP Signed-in Token (OoooooooRen) (cc77bb5fdd71 (Tautulli))
Feb 13, 2025 11:14:06.045 [22742625692472] DEBUG - Completed: [73.222.183.88:41478] 200 GET /library/metadata/1096395?includeMarkers=1 (15 live) #3554 GZIP 3ms 1307 bytes (pipelined: 1)
Anyone else have this issue? I can’t use Plex desktop on my Mac because of this issue.
I had this error when the windows audio output device was not working.
