Another Plex Chromecast problem thread
Just recently I have found that I cannot cast to my TV from my ipad. I am running Plex server on a WD PR41oo server. I can cast BBC player, or other TV apps, just not Plex. I have the cast icon but when I touch it, there are no devices found.
Was running app version 1195 and just applied the update to 1215. It has made no difference.
But, oddly I can cast from my Android phone, also runnning 1195 at present.
can try these:
Turn on Local Network access
  • iPad Settings → Plex → Local Network = On.
  • If it was Off before, delete and reinstall Plex to trigger the prompt again.
  • Also check Settings → Privacy & Security → Local Network → allow Plex.
  1. Disable anything that hijacks networking
  • Turn off VPNs, iCloud Private Relay, Cloudflare WARP, AdGuard, NextDNS apps.
  1. Confirm discovery works on iPad
  • Open the Google Home app. Your Chromecast must appear there.
  • Put iPad and Chromecast on the same Wi-Fi name (same SSID).
  • On the Wi-Fi, turn off client/AP isolation.
  1. Plex app cleanup
  • Force-quit Plex, reopen, try again.
  • Sign out of Plex in the app, sign in again.
  • Delete and reinstall the app.
  1. Network knobs that matter
  • Your LAN must allow mDNS: UDP 5353 between iPad and Chromecast.
  • Keep both on 5 GHz Wi-Fi where possible.
  1. About DNS
  • config.claspws.tv can affect starting playback in the new app, not device discovery. Keep it reachable.
  • Allow a DNS rebinding exception for plex.direct on your DNS resolver.
  1. Workarounds that get you going now
  • Use AirPlay from iOS Control Center.
  • Cast from Plex Web on a computer.
  • Use the older Plex iOS app build you have.
  1. Still stuck? Read the Plex Dashboard while casting
  • Plex Web → Status → Dashboard. Check the session:
    • Connection should be Direct.
    • Playback should be Direct Play or Direct Stream.
      If it shows Transcode, lower the cast quality or remux to MP4 to reduce load.
Thanks very much for your suggestions. It actually started working again yesterday evening. But I looked at your list:
Items 1-3 yes, all good. Actually the Chromecast is wired, so one less possible point of failure.
  1. Will try thaty if it stops again.
  2. Your LAN must allow mDNS: UDP 5353 between iPad and Chromecast - not sure how Id go about that.
  3. Thats getting a bit above my paygrade now :confused:
