Been searching for a while, as I’ve had this issue for several months. Since we also have an iPhone and iPod Touch, and they are readily available, I just reach for them when the Android devices fail (which is all of the time now).
Not a single Android device using the Plex app can Cast to Chromecast.
It might be easier to explain what does work, so y’all can understand what doesn’t.
Plex App for iOS and Android has the following that works perfectly fine (Nexus 10, Nexus 7 FHD, Nexus 5X, iPhone 6, iPhone 5S, iPod Touch 4th gen, Surface 3 LTE w/Windows 10).
- can play any movie, TV show and music.
- can play under Limited User under Android.
- can switch users (local users for family members, single Plex Pass account).
- can sync across all devices.
- can sync to limited user account on Android.
In addition, all Android devices can Cast anything else to Chromecast such as: Netflix, Google Photos, the actual Screen/device view itself, Google Play (Music and videos), YouTube, etc. Only Plex on Android cannot Cast.
Basically, the Windows, Android and iOS Plex apps work perfectly fine for any normal use on those devices.
Only iOS Plex apps can Cast to Chromecast.
However, my Android devices cannot Cast to Chromecast (Windows 10 cannot Cast, without the Chrome Extension that is).
This is an issue across all of my Android devices, as noted above:
- Nexus 10
- Nexus 7 FHD
- Nexus 5X
All of the Android devices have the latest versions of:
- 6.0.1 firmware.
- Plex app.
- Chromecast devices firmware.
- Plex Server is technically 1 version behind, but I didn’t see anything in the update notes about this.
NOTE: This all worked fine last year, with the older Chromecast. During Christmas, I bought and installed the updated version of the Chromecast. Nothing worked then as everything needed to be reconfigured. Only over the last few months have I sat down and gone through all the devices to connect them to the new Chromecast. not sure if the issue is related to changing devices, or Plex app update.
NOTE2: I’ve never got “Secure” connections or whatever that is working. I constantly have random issues across Windows 10, Android and iOS devices trying to use the Plex all. Completely unstable. It is so bad that the first thing I do when install Plex on any of these devices is to immediately jump into settings and “Allow Insecure Connections.”
NOTE3: I do not allow Remote Connections to Plex Server (basically, I disable the remote connections thing that does UPnP and opens a port). I use all of my devices on OpenVPN using my router and that handles all of our remote needs, and very securely.
