Hello, sorry for the stupid question…
I receive this popup message:
You’ve asked questions that now have answers. Make sure you accept/reject the answers.
10 times every second. If I click on the link, I not find any way to accept the answer.
I am becoming creazy, pls help me
Thanks in advance, sorry for bad english.
You’re not crazy. The forum software is. It gets itself into this state fairly often. So often that I’ve quit using the ‘Ask a Question’ option and instead use ‘Start a Discussion.’
You might be able to clear it by going to a thread where you started a question and post a reply. Your new reply should have the “Did this answer your question” prompt. You can answer Yes or No, and this might stop the popup from appearing.
If that doesn’t work, then a forum admin will have to do something on their end.
Thanks a lot. It solved the problem…
