Any fix or work arounds for playlist on IOS?
I was wondering if this has been addressed yet. I have this really cool app that I use to generate music slideshows with my music library, but, none of the playlists I create in Plex show up. I can see really old playlist, but, not any new ones. Is there anything I can do to get this to work?
Also, as a side note, I’d love to plug this app, if there is a forum thread for that. It works great with Plex too.
Server Version#: latest windows
Player Version#: latest
You’ll probably need to reach out to the developer of this „really cool script“ as it’s likely based on how they access your data/playlists.
It’s not a script. It’s a utility app for windows that generates timelines for a video editor. You generate a timeline, load it into a video editor, render it, then add the video to Plex.
But my original issue is playlists that are created on windows for plex no longer show up in the iOS device.
They no longer show up in the iOS Plex app but do in other Plex apps?
Well, actually, it’s only on the iPhone. My setup is Plex is on a Windows PC and I have FireStick and Apple TV and they show up there, just not on the iPhone. All OS’s are up to date too.
What version of the Plex app do you have on your iPhone?
Would you mind sharing where you’re looking for the „missing“ ones and how they show up on the web app (maybe using a screenshot)?
The app just updated an hour before this post and it’s fixed. But, you now have to turn the playlist library on. To do that, from the home page of the app on your iPhone, scroll down till you see “Browse Libraries”. Scroll that menu item to the left till you see “See all libraries”. Click that and you are in “favorite libraries” at the bottom, click “see all libraries”. Click that and add Playlists by clicking the heart icon. After that, it works.
Just update the app from the Apple store. It is also in the release notes that it was fixed.
