Just wondering if you could help me out. Running Plex Connect on DS213+ I am trying to connect this to my ATV3. My DNS (IP_Self: 192.168.0.251) I have manually added this into the DNS on ATV3 Nut I am still not able to connect.
Could some have a look at the logs below from DS231+, getting the following error:
14:42:04 WebServer: started: 14:42:04
14:42:04 WebServer: Failed to connect to HTTPS on 192.168.0.251 port 443: [Errno 98] Address already in use
14:42:04 PlexConnect: WebServer_SSL not alive. Shutting down."
Any Ideas on how I go about connecting my Ds213+ to ATV3?? I have been at this for the last 2 days and im still uable to get it working
Firware is 6.0.2
DiskStation> #!/usr/bin/python
DiskStation> ./PlexConnect.py
14:42:04 PlexConnect: ***
14:42:04 PlexConnect: PlexConnect
14:42:04 PlexConnect: Press CTRL-C to shut down.
14:42:04 Settings: add section PlexConnect
14:42:04 Settings: add option port_pms=32400
14:42:04 Settings: add option port_webserver=80
14:42:04 Settings: add option ip_plexconnect=0.0.0.0
14:42:04 Settings: add option certfile=./assets/certificates/trailers.pem
14:42:04 Settings: add option ip_dnsmaster=8.8.8.8
14:42:04 Settings: add option loglevel=Normal
14:42:04 Settings: add option enable_dnsserver=True
14:42:04 Settings: add option logpath=.
14:42:04 Settings: add option ip_pms=192.168.178.10
14:42:04 Settings: add option enable_plexgdm=True
14:42:04 Settings: add option hosttointercept=trailers.apple.com
14:42:04 Settings: add option port_ssl=443
14:42:04 Settings: add option enable_webserver_ssl=True
14:42:04 Settings: add option prevent_atv_update=True
14:42:04 Settings: add option port_dnsserver=53
14:42:04 Settings: add option enable_plexconnect_autodetect=True
14:42:04 PlexConnect: started: 14:42:04
14:42:04 PlexConnect: IP_self: 192.168.0.251
14:42:04 DNSServer: started: 14:42:04
14:42:04 DNSServer: ***
14:42:04 DNSServer: DNSServer: Serving DNS on 192.168.0.251 port 53.
14:42:04 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.251
14:42:04 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
14:42:04 DNSServer: forward other to higher level DNS: 8.8.8.8
14:42:04 WebServer: ***
14:42:04 WebServer: WebServer: Serving HTTP on 192.168.0.251 port 80.
14:42:04 PlexConnect: Shutting down.
14:42:05 WebServer: Shutting down.
14:42:09 DNSServer: Shutting down.
14:42:09 PlexConnect: shutdown
Thanks in advance
Robbie
