Hi
Hopefully this post is located correct:/
Is it possible to have more than more than 20 active streams?
Kind regards
Hi
Kind regards
If you’re running your PMS on a server that’s strong enough with a sufficient network bandwidth (and internet upload speed – if this should include remote streams) – sure… why not ![]()
Limiting factors could be:
For a more specific answer you’ll need to share some more details on your specific use case.
Hi Tom
I have morer than enough of everything - Plex only allowes 20 streams at a time, so i’m seeeking a way around this?
More* that is.
In “transcoding” the max number is 20, can something be done about that, that’s my question:)
The max setting is Unlimited.
Look at the top of the list, above 1.
Oh my god:)
I’m imbarrassed - thanks a bunch, really appreciated:)
