Any way to integrate/use a not supported DVB tuner?
Hello,
is there any way to integrate/use a DVB tuner that is not on the list of supported tuners?
My Digital Devices tuners are not on the list, but Plex found them immediately when I set up my Live TV & DVR.
Hello,
I was told that this is PLEX support, there is no one else. But guys, honestly, if no one helps, then this is no support. Not even the head of this subforum can give me an answer, so I am very, very disappointed, and am now trying again.
I hate to point out the obvious, but you are looking for support on unsupported devices. That means no support. Expecting support for them, from Plex, is not going to happen.
If a user has somehow figured out how to do so, they are under no obligation to tell anyone else their solution, and if they do tell anyone, that does not imply any such idea of being supported.
If you want it to work, with support, use supported hardware. If not, don’t complain that you are on your own when trying to get it to work.
It’s all good, I just expected to at least get an answer. That can’t be too much to ask. If someone tells me that no, it doesn’t work with other tuners, then that’s fine…
I use tvheadend to control my unsupported tuners and connect Plex to that via tvhproxy
Hello,
I’m using two unsupported tunners, connected to a USB Hub, for more than 1 year, with no issues (at least, no more issues than the folks using official tuners report). As e10kstarfire and many others, I’m using TVHeadend + TvhProxy.
If you want the details of my tuners, sen me a PM.
Thank you for your answer. My tuners are PCIe tuners. Not connected outside the computer via USB, and my Plex server runs on a Windows W10 computer. Does this method with tvheadend also work? And if so, where can I find a little guide on what to do? gruß, d.
I have PCIe tuners, works fine. But running Linux (actually unRAID) and tvheadend docker controlling the tuners.
Sorry can’t help with Windows.
Is there anyone who can tell me something about tvheadend and Windows, or help me, please?
