Any way to shut down PC from Plex Media Player interface?
Hello
Only thing I’m missing from PMP is to shut down the PC from the interface. Is it somewhere hidden and I’m just blind?
Loving the design!
Cheers
PMP on Windows, Mac, or Embedded ?
Sorry for missing out on that -> Windows.
I couldn’t find it either, so I mapped a button on my remote to the start menu for windows 10 - Shift ESC and then press this, it pops up the start menu and I can select sleep or reboot, or even power off.
It’ll do for now until plex adds the function into the menus.
Its in the works: https://github.com/plexinc/plex-media-player/issues/283
It’s already working on OS X, if you build it. I haven’t tested Windows though
Windows is not done yet.
But it will come eventually?
Sounds great to me, thanks!
Come in next week RC.
I don’t know about a Mac solution, but if someone is looking for a solution under Linux, I created a script that automatically Shuts Down the PC if Plex isn’t transcoding within 1 hour…
It’s free and open source, available at:
Surely you can’t have all missed this??
Keep hitting Back and you will get the Exit menu, where you can…
Exit
Power Off <----- It’s right here!
Reboot
Suspend
Cancel
Cheers… Andy
Hello ,
I was looking for the same info .
But is it possible to do it from the app also ?
Turning off remotely the computer ( windows here ) from my tablet app ( iPad or iPhone ) , after the end of my movie .
Didn’t Find button for that in the app…
Thanks for your help
You can’t shut down the server from a client app.
Since there is no way to turn it back on from a client app.
hi thanks for the answer otto.
why does this have to be run both way ?
i just want to be able to turn off my computer ( plex server ) that is downstairs, after viewing a movie in bed on my tablet ( this is upstairs )
i’m sure i’m not the only one that would like this feature… :wink:
