Anybody else having issues with DLNA since PMS v1.10.1.4561?
I’m currently struggling to get DLNA back to work. Used to work fine but now I can no longer access Plex’ DLNA from my TV or other clients.
So far I have…
  • de-activated / re-activated DLNA inside PLEX
  • re-started the PMS
  • re-booted the server
  • re-booted my router
  • re-started the TV
  • reviewed PMS firewall settings and finally deactivated it entirely
so far to no good.
According to the Plex’ logs, DLNA is running.
Any ideas?
same here… exactly same thing…
same here. realized LOGIN PROBLEMS into PMS since update 1.10.1.4561?
Manually attempts to log in fail with error: PMS not availabel (which in my case is 127.0.0.1 so local on same PC where I try to open PMS WebGUI!).
Only thing I can do for now is to wait 1-2 minutes 'til the AutoLogin does its job withot any manual interaction.
seems it wasn’t so much a plex issue.
when activating another DLNA server on my Synology, this somehow caused the DLNA client to re-search the network and re-find my Plex DLNA. Happy once more :slight_smile:
