anyone else having problems with silicon dust extend ? tuning channels
i have it hooked up to my WDPR4100 Nas drive. not all channels can be tuned to, however some can be. "Unable to tune channel (Timed out)"is error i get. If i log on to NAS drive turn off the Plex app then back on it works for a short while.
I’ve had some of that. It seems to see the station but won’t actually tune to it. I think it’s my own indoor antenna placement though, as it’s not close to a window. I tested signal strength with it stretched at the window and it was much better. Unfortunately that’s not feasible, but I may have another solution.
i have a roof top antenna and signal strength is good.what might your other solution be?
My problem was I didn’t have as good of reception as I thought. So I used old cable lines, found where they went, stashed the antenna facing the correct direction to where the towers are, and put the tuner in the basement where I could wire it into my network. So it’s a very personal problem with a personal solution, which seems to have solved the issues. Maybe check where your local broadcasting towers are.
