Could not tune channel. Please check your tuner or antenna
Plex is giving me error “Could not tune channel. Please check your tuner or antenna.” on every single channel I try to stream on the web client, android, smarttv, and iOS.
I currently running Plex in a Docker container on Unraid. I also have a HDHomeRun Connect Duo. The HDHomeRun app works perfectly on both Windows and Android so the problem is somewhere in plex.
I have a thread open on this, and has been open for sometime. I don’t know if you should post in there, but wanted to share it with you none the less.
