Hmmm, no more blocky weirdness when transcoding HDR ? If yes that’s some progress to say the least
Running on Intel NUC 11th gen TNHi5
Ubuntu HWE kernel 5.14 with official plex docker container (using macvlan driver and igpu passthrough)
Linux dummy_host 5.14.9-051409-generic #202109301541-Ubuntu SMP Thu Sep 30 15:54:45 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Also crashes when I jumped through a couple of transcoding modes (original/convert automatically/720p/480p/1080p).
Tested on both plex public and beta.
5112.594692] i915 0000:00:02.0: [drm] Resetting vcs0 for preemption time out
[ 5112.596494] i915 0000:00:02.0: [drm] GPU HANG: ecode 12:4:28fffffd, in Plex Transcoder [29075]
[ 5121.141488] i915 0000:00:02.0: [drm] GPU HANG: ecode 12:4:28fffffd, in Plex Transcoder [29075]
[ 5121.142514] i915 0000:00:02.0: [drm] Resetting vcs0 for stopped heartbeat on vcs0
[ 5121.143069] i915 0000:00:02.0: [drm] Resetting chip for stopped heartbeat on vcs0
[ 5121.334647] i915 0000:00:02.0: [drm] ERROR Failed to reset chip
[ 5121.336278] i915 0000:00:02.0: [drm:add_taint_for_CI [i915]] CI tainted:0x9 by intel_gt_reset+0x24c/0x2d0 [i915]
[ 5121.441329] i915 0000:00:02.0: [drm] Plex Transcoder[29075] context reset due to GPU hang
[ 5126.358289] Fence expiration time out i915-0000:00:02.0:Plex Transcoder[29075]:15fa!
[ 5139.025438] show_signal_msg: 19 callbacks suppressed
If I choose Convert Automatically with H264 1080p (8.5mbps) files I get some glitches.
Message
[Transcode] Streaming Resource: Estimated bandwidth for hamihth9iyllhqxxk9x0stf2 to be 28939kbps over 11.33s
If I change it to a fixed quality setting, I don’t have glitches.
Any progress on this topic ?
My old NUC died and I just replaced it today with a new NUC11PAHi5 (Tiger Lake, Iris Xe). And then I found this thread while trying to figure out why HW transcoding wasn’t working…
I’m running stock Ubuntu server 20.04.3 with the 5.4.0-88-generic kernel and no additional Intel drivers or kernel modules. Plex is running directly on the system, there are no containers. I’m happy to give Plex devs remote access if it would help, and I’m more than happy to try different kernels and modules, though looking through the thread it doesn’t seem like there’s anything promising so far.
Robbie
Hope you’ll wait less than other here (8month topic)
and
So i think they are trying to bring it in the new transcoder release but they are not sure yet
I know there’s a bigger Tizen issue going on but don’t want to lose track or visibility on this issue as well. Looking for an update as my pretty NUC11 is just that, a pretty paperweight for now.
literally when I posted this, it crashed.
No errors showed up in dmesg and somehow I had a plex crash log, but it seems to be deleted as soon as plex restarts.
First attempt with the current setup, failed and even made the server unresponsive.
Second attempt, I have 4 transcodes running (with every option except the disable stream on in plex) so far so good, without any crashes, but i’m still monitoring it.
What have I changed?
sudo add-apt-repository ppa:tuxinvader/lts-mainline
sudo apt-get update
apt install linux-generic-5.14
wget -qO - https://repositories.intel.com/graphics/intel-graphics.key |
sudo apt-key add - &&
sudo apt-add-repository \
'deb [arch=amd64] https://repositories.intel.com/graphics/ubuntu focal main'
sudo apt update &&
sudo apt install \
intel-opencl-icd \
intel-level-zero-gpu level-zero \
intel-media-va-driver-non-free libigfxcmrt7 libmfx1
reboot
docker-compose down && docker-compose up -d --remove-orphans
If anyone is willing to test this and share the results, if it seems to be ok, I think we might be on the way to a functional setup
So is it better to stick with an Intel 10th gen for now, instead of the 11th gen? Is there a timeline to fix this issue?
I went out and got a NUC8 for Plex. I’d suggest purchasing something other than an 11.
There hasn’t been much in the way of updates shared here by Plex and no ETA provided.
Pretty disappointing TBH
Thanks !
Here’s my reply :
Finally, we see the light at the end of the tunnel…
My tests are also very very promising.
no dmesg errors, cpu around 30% and average of 30% rendering, 20% video0 & 1, 5% enhance on the igpu.
i don’t have tone mapping enabled.
Linux philip-price 5.14.11-051411-generic #202110100930-Ubuntu SMP Sun Oct 10 09:41:38 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Running plex in docker with the latest (1.24.6.5145-dff9113d3) transcoder preview.
installed packages:
libgl1-mesa-dri/focal-updates,now 21.0.3-0ubuntu0.3~20.04.3 amd64 [installed,automatic]
libglapi-mesa/focal-updates,now 21.0.3-0ubuntu0.3~20.04.3 amd64 [installed,automatic]
libglx-mesa0/focal-updates,now 21.0.3-0ubuntu0.3~20.04.3 amd64 [installed,automatic]
mesa-utils/focal,now 8.4.0-1build1 amd64 [installed,automatic]
mesa-vulkan-drivers/focal-updates,now 21.0.3-0ubuntu0.3~20.04.3 amd64 [installed,automatic]
intel-gpu-tools/focal,now 1.25-2 amd64 [installed]
intel-igc-cm/focal,now 1.0.40+i611~u20.04 amd64 [installed,automatic]
intel-level-zero-gpu/focal,now 1.1.20678+i611~u20.04 amd64 [installed]
intel-media-va-driver/focal,now 20.1.1+dfsg1-1 amd64 [installed]
intel-microcode/focal-updates,focal-security,now 3.20210608.0ubuntu0.20.04.1 amd64 [installed]
intel-opencl-icd/focal,now 21.33.20678+i611~u20.04 amd64 [installed]
libdrm-intel1/focal,now 2.4.107-1028 amd64 [installed,automatic]
What happen when you guys enable tone mapping ? same stuff as before on screen or completely gone ?
When tone mapping is enabled, for me at least, the transcoder reverts back to software
I enabled tone mapping now, but didn’t notice any changes in performance or load on the cpu.
There are no errors in the plex console, no glitches or such have been noticed as well.
but I believe that I don’t have any media that uses HDR or benefits from tone mapping.
The most common issue with tone mapping (and somehow Live TV) when transcoding was blocky artifacts (and pretty much unwatchable content), leading to a GPU crash, wonder if it is also fixed.
I’m whilling to test the beta but I better wait for it to be polished and ready with public releases so I’m mostly waiting for reviews from users that got access to this particular beta.
segfault in dmesg.
At least the kernel is not tainting i915, which allow Plex to continue its execution.
IMO, the best solution with this build is to keep Hardware Decoding/Encoding ON but Tone Mapping OFF.
Personally I’m using an Nvidia Shield TV on a SDR TV screen.
I noticed that HDR data seems preserved when HW transcoding, instead of being converted to SDR, which allow then the Tone Mapping to happen on the Client side instead of the Server side (Nvidia Shield TV has Tone Mapping support).
So no washed-out videos anymore for HDR videos on SDR screen.
I admit the Tone Mapping solution is still not perfect (Iris Xe has Hardware-capable Tone Mapping), but at least HDR videos are displayable.
Hmm… on 5.14.11 (and plex in docker) I don’t have segfaults in dmesg.
Only some perf interrupts that took to long.
This is very good news though, at least we can finally use the hardware as intended, let alone the segfault and HDR stuffs can still be fixed in further updates since it’s still experimental.
Pretty sure further updates will allow Iris Xe and future iGPU to take advantage of it’s HW capable tone mapping, at least that’s what we’re hopping.
Finally …
Tested today in a docker container on Unraid and so far works very well …
3 concurrent streams with hardware transcoding : CPU burst @ 35% max but mainly around 10%. GPU @ 60%.
Not tested tone mapping, but as yet I’m happy with what I have today
