Hello. While watching Martha Stewart channel when it goes to break or commercial channel buffers then errors out. This doesnt happen while viewing other channels for me. Anyone having this issue? I uninstalled app. Rebooted. Localized to Martha Stewart channel and issue I stated. Please if anyone has a fix or is having same issue. Please report.
Using plex version 10.26.0.2578 located in United States
Could you tell which particular Plex app you are using?
And which country are you located in?
Hi. Version 10.26.0.2578
Com.plexapp.android
I found the app in settings. Just cleared data, cashe. Foresed stop. Re opened. Troubleshooting now to see if any of that helped.
Just this channel. Everything else working on plex for me. Thxs
None of what I did. Any break in program (commercial) buffers then error.
Error says
An error occurred while attempting to play this video. Please check your connection and try again.
App version 10.27.0.2681
Fire Stick 4K Max gen2
Edit: Yeah, I confirm this now.
Right when the segment ended it rolled out and instead of going to commercial it’s now sitting on a spinner. Haven’t gotten an error yet but it’s been spinning for over a minute now.
Thank you for the report!
I have forwarded this to the team for investigation.
