Anyone using blackwell based GPUs (5060 TI) for transcoding?
Hi there!
I am currently using an Intel arc based GPU for Plex transcoding which works great but i am about to switch to Nvidia because i also want to be able to use the GPU for machine learning processes (whisper, n8n etc).
Does anyone here have experience transcoding on plex with a 5060 TI or simlilar?
How many transcoding streams can you handle and how good is the end result?
Thank you!
Would appreciate any insight from the Plex team regarding which GPUs actually have good support with Plex.
I’m running fedora 43 with a nvidia 5070 gpu and have zero problems with transcoding. GPU is generally under 10% usage when plex is transcoding and pulling approx 30w of power. Beyond that not sure what else to say.
Thank you dokuro!
